Activity Forums Apple Final Cut Pro Legacy Blackmagic doesn’t like me….
  • Blackmagic doesn’t like me….
    Posted by Brian Pitt on June 20, 2006 at 9:11 pm
    I have a Blackmagi Decklink SP capture card that is acting up. I use this to monitor video by going directly to a Sony Bectacam SP UVW-1800 Deck and from there into the monitor (Sony HR Trintron). I haven’t had any problems until today. I needed to view a Beta Tape, but as soon as I took the tape out and went back into FCP, the picture that was sent out to my monitor was black and white and a little bit scrambled. I didn’t change any settings. I have tried powering off the deck and restarting my computer but nothing is working. I also completely disconnected the capture card cables, but NOTHING!!!
    I have no problems when playing back a tape in the deck, but when I send a signal from FCP or any other application that allows this, the signal is black an white and scrambled. Any help/suggestions would be appreciated!!!
    Brian
    Brian Pitt replied 20 years, 2 months ago 3 Members · 4 Replies
  • Brian Pitt
    June 20, 2006 at 9:57 pm
    Okay, it looks like it’s a problem with the deck and not the card. My monitor has component inputs and I hooked up straight to that with no problem. Is there a setting in the deck that might have gone crazy? The deck has black burst going to it, so I don’t see what the problem could be…
    Brian
  • Peter Sassi
    June 21, 2006 at 2:25 am
    Brian,
    I have seen this with BM Extreme. It has happened to me when things got too hot (temp). I’m in FL and our AC went out last summer for a day. I got, what seems to be, the same B&W scrambled signal you describe for a while. Shut down, left it cool and opened up the cover of my old G4 and let it run with cover open and a fan on it and viola` until the AC was fixed. I was on a deadline of course. I don’t know if heat is a factor in your equation or not.
    -peter
  • Erik Jägberg
    June 21, 2006 at 8:59 am
    Make sure you have the right settings in System Settings/Blackmagic Decklink.
    Should be Analog Y, B-Y, R-Y and NOT Analog NTSC/PAL (Y in).
    Editor
    Monitor Flm & Television
    Stockholm, Sweden
    G5, 2*2.5ghz, 2 gb ram, 600gb Huge raid, Blackmagic Decklink extreme, Apple 23″ Cinema display.
  • Brian Pitt
    June 21, 2006 at 3:54 pm
    THat may have been the problem because everything was working when I fired it all up this morning. thanks!
