Activity › Forums › Blackmagic Design › Blackmagic Disk Speed Test – Disk Full??
Posted by Steve Lim on May 16, 2005 at 4:16 amHi,
We just bought 2 decklink extreme cards for our Dual G5s. After installation, I tried running the Disk Speed Test and get an error that the Disk is full. Whats going on?
I have 2 400GB SATA drives striped using macOS built in raid.Pls advise..
Thanks.
StevePeter Sassi replied 21 years, 4 months ago 5 Members · 7 Replies -
Kristian Lam
May 16, 2005 at 5:50 amHi Steve,
Did you run Disk Speed Tool from the drives you’re testing? It installs to your startup volume by default.
Regards
Kristian Lam
Blackmagic Design -
Steve Lim
May 16, 2005 at 6:00 amHi,
I do not understand. I have 2 * 400GB SATA drives striped as one 800GB drive. I do NOT have any external drives or anything. I just wish to see benchmark the 800GB volume (the same volume that would be holding the video data in time to come).
Wolf
May 16, 2005 at 6:27 amin the “Disk Speed Test” Tool you have to select the drive you wish to test.
It -
Steve Lim
May 16, 2005 at 6:45 amInstalling the latest 4.8 drivers seemed to have fixed it. We had 4.3 installed.. argh.
Peter Sassi
May 16, 2005 at 11:40 pmWhere is the option to choose the disk you want to run the test on?
thanks,
peter
Matthew Small
May 17, 2005 at 6:45 pmYou need to copy (drag & drop) the application itself onto the hard drive you wish to test and run (double-click) it from there.
Matt Small
Pair of Hands
Sherman Oaks, CA“If it was easy, everyone would do it.”
