Activity Forums Blackmagic Design Blackmagic Design TV Studio SD output from laptop
  • Blackmagic Design TV Studio SD output from laptop
    Posted by Harry Ranhot on August 8, 2012 at 1:22 pm
    I’m trying to mix 2 sd cameras (cony pd177) and a laptop output. i’m able to get cameras to the TV Studio using BMD analog to sdi converters. My laptop has an HDMI output port but i’m not getting the output to TV Studio. i’ve trying using different resolution settings but no use. It just show blue screen at ATEM TV STUDIO for laptop output. BTW i’ve tried changing cable and even laptop (DELL XPS Studio) but same result.
    Any ideas please???
    Kind regards
    Harry
    Harry Ranhot replied 14 years ago 3 Members · 5 Replies
  • Mihkel Mäemets
    August 8, 2012 at 7:04 pm
    Have you set your laptop’s resolution to match ATEM TVS signal type. ATEM doesn’t have any built in scalers.
    I’ve successfully mixed computers an SDI sources, but all resolutions must be the same.
  • Brendan Stark
    August 8, 2012 at 8:36 pm
    You’ll need to set the laptop output to 525i5994 NTSC. That may or may not be possible depending on the video card, but it’s a really small screen size for Windows. Most of the time you’ll want to convert the signal via something like a Matrox MX02.
  • Harry Ranhot
    August 9, 2012 at 11:02 am
    My cameras are PAL version.
    Mihkel: Can you please share your laptop resolution settings please.??
    Brendan: i’ve no such resolution available in my laptops like 525i5994 NTSC. can please share more details please. resolution/refresh-rate etc.
    mnay thanks and kind regards
    Harry
  • Mihkel Mäemets
    August 9, 2012 at 8:45 pm
    Try setting the output setting to 720 x 576 50 Hz Interlaced.
    This should match your system settings in ATEM TVS.
  • Harry Ranhot
    August 10, 2012 at 4:00 pm
    I will check and report it tomorrow.
    Many thanks and regards
    Harry
