Activity › Forums › Blackmagic Design › Blackmagic Design release version 5.0 for MAC and Windows updates
Yves De muyter replied 21 years, 2 months ago 7 Members · 13 Replies
Wolf
July 14, 2005 at 8:24 pmHi rhani,
yes, i also found this way, but i don’t want to change those things
for every clip in my timeline.
i have better things to do.But thanxs any way 🙂
Feue mich schon wenn diese Treiber endlich mal richtig laufen 🙂
Manololp
July 16, 2005 at 12:22 amHello. Caveats with Premiere Pro: https://www.blackmagic-design.com/support/detail.asp?techID=108
Yves De muyter
July 16, 2005 at 6:33 amDear BMD,
> Also, you can play out the PAL DV sequence to tape with DeckLink, and then
> recapture to uncompressed, and it will be OK. We set the fields correctly
> when playing a PAL DV clip out to the SDI output.This doesn’t seem to apply on our customer’s system. Any playout of DV in a DV-project seems to be upperfield, and thus, has fields swapped.
Playout includes export-to-tape and just previewing the playlist.I have 2 solutions I proposed to the customer:
1. is to create a new sequence, import the main sequence into that sequence and move the video 1 pixel up and render it out.
2. is to create an upperfield DV project and reverse field dominance of all captured clips. This is far the best solution, the only problem with this is that exported DV tends to be upperfield and that might become a nightmare exchanging media with other systems.-Yves
