Activity Forums Blackmagic Design Blackmagic Design HDLink Pro DVI – bigger screens than 30″?
  • Blackmagic Design HDLink Pro DVI – bigger screens than 30″?
    Posted by Aleksander Steffensen on March 7, 2012 at 12:52 pm
    Hi!
    I am considering purchasing several HDLink units to use with 42″ monitors that are part of a TV studio. I figured this is a considerably cheaper way to get SDI into the monitors, rather than buying dedicated SDI I/O cards for the monitors.
    However, after reading the specs on BMD’s website, I noticed that they say “Supports SD, HD and 2K using Dual Link DVI-D displays up to 30 inches 2560 x 1600 in size.”. This might be a stupid question, but does this really mean that the HDLink cannot be used to send a 1080p DVI signal to a 42″ monitor, only up to 30″?
    Thanks in advance!
    Steffensen Multimedia
    Aleksander Steffensen replied 14 years, 5 months ago 2 Members · 2 Replies
  • Kristian Lam
    March 7, 2012 at 10:52 pm
    The requirements are really referring to Dual Link DVI-D displays up to 2560×1600. The size of the screen does not matter.
    If you’re going to be sending your DVI signal to a 42″ display that is just 1920×1080, it will be fine.
    regards
    Kristian Lam
    Blackmagic Design
  • Aleksander Steffensen
    March 7, 2012 at 11:24 pm
    Excellent! Thank you, Kristian!
