Activity Forums Adobe Premiere Pro Blackmagic design and Premiere Pro
  • Blackmagic design and Premiere Pro
    Posted by Thomas Mikkelsen on November 8, 2011 at 1:45 pm
    Hey
    I am new to premiere and as manny others switching from FCP7
    I own Premiere Pro cs.5.5
    I am having troblem with the output from my Blackmagic Hd extreme 2 card.
    Premiere seems to be working fine when my player settings are set to Adobe Player but when i select
    Blackmagic the source window goes black and i dont get anny output on my HDSDI screen.
    I have tried all kind of material but at the moment it is Proress 4444 from a alexa camera.
    My system
    MacPro 2×2.8 Ghz Quad-Core Intel xeon
    16Gb Ram
    Black magic HD extreme 2 and HDSDI monitor.
    Have annybody had the same problem ?
    Thomas Mikkelsen
    Editor
    M2film.dk
    Thomas Mikkelsen replied 14 years, 8 months ago 6 Members · 11 Replies
  • 11 Replies
  • Chris Tompkins
    November 8, 2011 at 4:00 pm
    Reinstall the BMD driver after installing Adobe.
    Chris Tompkins
    Video Atlanta LLC
  • Thomas Mikkelsen
    November 8, 2011 at 4:59 pm
    I have tried that unfortunaly that did not work still the same problem. I am running BM driver 9.0
    Thomas Mikkelsen
    Editor
    M2film.dk
  • Tim Kolb
    November 9, 2011 at 1:14 am
    Have you talked to the Black Magic guys about it?
    You’re designating the proper outputs, etc, right?
    TimK,
    Director, Consultant
    Kolb Productions,
    Adobe Certified Instructor
  • Ray Tragesser
    November 9, 2011 at 3:07 am
    Hey Thomas,
    One more thing that gets often overlooked by newer users. In addition to selecting the Blackmagic Player in the preferences, you need to use a Blackmagic sequence preset. Often new users are using a native Adobe sequence preset and they don’t see anything on their monitor.
    Let us know if that does the trick.
    Ray
  • Pep Collados
    January 1, 2012 at 3:03 pm
    Hi Thomas!
    I’m just having the same problem with Premiere CS5.5.2+Blackmagic HD Extreme 2 and Blackmagic HD with Desktop Video 9 in three different MacPros.
    The problem disappears with Decklink HD Extreme 3D. Everything goes smooth with all codecs i’ve tried (Alexa APR, Canon H264, image sequences…), in source monitor and in sequences.
    I send a mail to blackmagic support team but i still have not received any answer. I hope they can give a better solution than buying two Extreme HD.
    Did finally find a solution to that problem?
    Thanks!!!
    Pep Collados
    Editor
    onpost.tv
  • Tom Daigon
    January 1, 2012 at 5:14 pm
    Customer support from BM is notoriously bad. What you save in $ buying their products, you lose in less than desirable technical / customer support.
    Tom Daigon
    Avid DS / PrP / After Effects Editor
    http://www.hdshotsandcuts.com
    Mac Pro 3,1
    8 core
    10.6.8
    Nvidia Quadro 4000
    24 gigs ram
    Maxx Digital / Areca 8tb. raid
    Kona 3
  • Pep Collados
    January 1, 2012 at 5:33 pm
    So I guess I’m lucky because it’s the first time I need their technical support in seven years working with their products… 😉
    Pep Collados
    onpost.tv
  • Tom Daigon
    January 1, 2012 at 5:54 pm
    Yes, you are very lucky!
    Tom Daigon
    Mac Pro 3,1
    8 core
    10.6.8
    Nvidia Quadro 4000
    24 gigs ram
    Kona 3
  • Thomas Mikkelsen
    January 3, 2012 at 10:15 am
    Hey Pep
    Thanks for the feedback.
    I still have the same problem and also tried BlackMagic support with no luck.
    But nice to here that the BM 3D extreme fixes it.
    I cant get my old card to work with it, but i would be nice to get an official announsment from Adobe or BM that if you what Premiere to work with BM then you need the new 3d card.
    Thomas Mikkelsen
    Editor
    M2film.dk
  • Pep Collados
    January 4, 2012 at 6:27 pm
    Hi Thomas,
    We got an answer from the Blackmagic guys:
    Hi Pep,
    Thankyou for your email.
    There are no incompatibilities I’m aware of between the HD Extreme 2 and Premiere Pro CS5.5. However we are no longer testing the HD Extreme 2 with new software. But the way each card functions is essentially the same.
    There are a few features that the HD Extreme 2 doesn’t have such as 1080p25/30 support, which the 3 and 3D do. But nothing that should cause problems with performance.
    If the Source monitor is not outputting, this is likely to be that the default player is not set to Blackmagic. You can change this in Premiere’s Preferences, under ‘Default Player’.
    If I can help further, please do get back to me.
    Regards
    Chris Pearse
    Technical Support Consultant
    Blackmagic Design EMEA
    So the problem definitely is that Extreme Hd and HD 2 don’t support 1080p25/30… If you try with 720 material it works properly but when you try to work with any kind of 1080p footage, such as Alexa or Canon H264, everything goes wrong in Premiere.
    Well, at least we know what is going wrong…
    Regards,
    Pep Collados
    onpost.tv
