Activity › Forums › Blackmagic Design › BlackMagic Decklink SP and Vegas / Component capture
  • BlackMagic Decklink SP and Vegas / Component capture
    Posted by Paulo Viana on January 22, 2007 at 5:54 pm
    I bought a Decklink SP to capture betacam (Sony PVW-2800 / via component). I heard that Vegas software doens’t allow capture component from BMD. Is it true? Because I’m heaving problems to configure the BMD to capture.
    Paulo
    Gordan Antic replied 19 years, 8 months ago 2 Members · 4 Replies
  • Gordan Antic
    January 26, 2007 at 4:09 pm
    yes it is unfortunately, and there is no hope.
    i am using j-30sdi for capturing even betacam sp.
    sony says that analog(component) ptt isn’t possible but i do it on daily basis with no problems (pvw-2800p).
    if i have to capture from pvw-2800p, i have to do it trough decklink’s deck control and blackmagic codec.
    regards,
    gordan
  • Paulo Viana
    January 26, 2007 at 6:09 pm
    Thanks x_gogoa.
  • Paulo Viana
    January 30, 2007 at 11:55 am
    X_gogoa,
    When you use SDI to capture videos via blackmagic, can you control PVW-2800 using Vegas Capture or you have to do it manually?
  • Gordan Antic
    January 30, 2007 at 11:44 pm
    when i capture from pvw-2800 i have to (and you too) use decklink’s deck control app ‘couse vegas can not capture analog source via decklink extreme card. deck control only captures in qt with blackmagic’s codec which can be used in vegas.
    i would really like to see vegas update with analog possibilitiy or deck control capture in avi with bmd or sony yuv codec or qt bmd codec optimised for multicore of multiprcessor platform.
    regards,
    gordan
