Activity › Forums › Blackmagic Design › BlackMagic Control Panel Greyed Out
  • BlackMagic Control Panel Greyed Out
    Posted by Mkleiman on August 20, 2006 at 8:12 pm
    FCP 5.1.1 & OSX 10.4.7 with Blackmagic SD Decklink Extreme. I’m running the latest Blackmagic software 5.7 and my second monitor (broadcast monitor) is not being recognized. In my system preferences the Blackmagic Icon shows up but when i open it all options are greyed out. I’ve uninstalled and reinstalled BMD software a couple of times with no result.
    Anyone know what’s going on?
    Mkleiman replied 20 years, 1 month ago 3 Members · 6 Replies
  • Mkleiman
    August 21, 2006 at 8:59 pm
    I am getting an error message in FCP when i change my easy setup to Blackmagic NTSC 8- bit. It reads: The computer doesn’t have Serial Port required for this protocol. Any ideas. I’m really stuck here.
  • Kristian Lam
    August 22, 2006 at 4:33 am
    As you’re running beta drivers, can I get you to download v5.6.3 from our site <https://blackmagic-design.com/support/software/> and install that instead. Do remember to run the “Uninstall Blackmagic” application first.
    regards
    Kristian Lam
    Blackmagic Design
  • Mkleiman
    August 22, 2006 at 5:31 pm
    I’ve tried Decklink 5.6.2 but I don’t see 5.6.3. Have you heard of this issue before?
  • Mkleiman
    August 22, 2006 at 6:34 pm
    found 5.6.3 and IT WORKED! Thanks so much. The name “multibridge” threw me.
    Mark
  • Kent Kajino
    August 23, 2006 at 8:04 am
    I was experiencing the same behavior with the original driver. In addition, 10-bit material wouldn’t play back. Only 8-bit material worked.
    Upgraded to the latest beta, the card started working (and the preferences, too), but it caused the G5 sleep problems, namely the OS wouldn’t see the keyboard and mouse, and the fan began to suck air like crazy after waking up.
    Went back to v5.6.3, and the sleep problem is gone.
  • Mkleiman
    August 27, 2006 at 7:32 pm
    well all was good for a while there and now the same problem is happening. the system isn’t recognizing a second monitor and the Decklink Panel is again greyed out.
