Activity Forums Blackmagic Design blackmagic control panel
  • blackmagic control panel
    Posted by Hung Han on March 22, 2011 at 2:04 pm
    Hi
    I have the products :
    * DeckLink HD Extreme 3D
    * DeckLink Studio
    My Software is not doing the down conversion (BlackMagic Control Panel > Processing > Output processing > any simultaneous hd and sd output) at DeckLink HD Extreme 3D, but at DeckLink Studio it does.
    The problem is that if I select the down conversion and than start my application and play a video file, the 8 Y OUT is black. But if i open the BlackMagic Control Panel again and select any simultaneous hd and sd output… it works (but this will cause another kind of problems)
    Like i said, this problem happens only at DeckLink HD Extreme 3D. But i know it is something at my code that is missing, because i changed your SDK application DecklinkPlayback.exe… doing what i want and the problem is not happening
    Could you tell me which command and where it is doing at your SDK application DecklinkPlayback.exe that specify the output to the output selected from BlackMagic Control Panel?!
    Best Regards
    Hung
    Hung Han replied 15 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
