Activity Forums Blackmagic Design BlackMagic codec>shake.. wierd artifacts..
  • BlackMagic codec>shake.. wierd artifacts..
    Posted by Simon Blackledge on May 16, 2007 at 11:03 am
    Captured some material off digi-beta BM 10bit uncompressed.
    Looks fine in FCP, and Quicktime.
    FileIn to shake and I get multi colored pixels dancing on the far right of frame?
    Also.. when I open the clip in QT and choose Export>same size, same FPS but change codec to uncompressed 10bit 4:2:2 it saves the file as blackmagic still? How do I export as just Apples uncompressed not BM ? And when I do this the dancing pixels on the right had of frame get less.. but are still there… 😕
    Anyone?
    Cheers
    P
    Simon Blackledge replied 19 years, 3 months ago 2 Members · 3 Replies
  • Luke Maslen
    May 17, 2007 at 2:46 am
    Shake 4.1 has some issues which we’ve logged with Apple. Are you using Shake 4.1 or an earlier version? Which versions of Mac OS X and QuickTime are you running. Are you using our freeware codecs or the ones installed by our drivers. If you have DeckLink or Multibridge drivers installed, which version are you using?
    Regards,
    Luke Maslen
    Blackmagic Design
  • Simon Blackledge
    May 17, 2007 at 6:28 am
    macpro 10.4.9 latest updates pro apps support and latest QT
    BM drivers are the latest off the site no the free codecs.
    Shake 4.1
    How can I export uncompressed 10bit 4:2:2 and not use BM 10 bit ? everything seems to revert to BM 10 bit.. :-/
    cheers
  • Simon Blackledge
    May 29, 2007 at 8:54 pm
