Activity › Forums › VEGAS Pro › Blackmagic codec
  • Blackmagic codec
    Posted by Larry Brewer on June 30, 2010 at 5:50 am
    My renders using the Blackmagic codec always result in setup being added. Video on the timeline with no setup, render using Blackmagic codec, and now I have just under 10% (7.5% maybe?) Anyway to turn off setup when doing an AVI render with Blackmagic settings?
    Larry Brewer
    Larry Brewer replied 16 years, 3 months ago 2 Members · 4 Replies
  • John Rofrano
    June 30, 2010 at 11:19 pm
    This would have to be a feature provided by Blackmagic. Press the Custom… button in the Render As window to edit your template. then on the Video tab press the Video format Configure… button with Blackmagic selected and if it allows configuration, it will be in there.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Larry Brewer
    July 1, 2010 at 12:50 am
    The config button is grayed out.
    So that won’t work.
    Larry Brewer
  • John Rofrano
    July 1, 2010 at 2:19 am
    So that means that you need to ask Blackmagic Designs about this since they don’t allow you to configure the codec.
    ~jr
  • Larry Brewer
    July 1, 2010 at 6:25 am
    I am waiting for them to get back to me on that.
    Thanks for your attention to this.
    Larry Brewer
