Activity Forums Blackmagic Design blackmagic codec for p2 23.98 720 p?
  • blackmagic codec for p2 23.98 720 p?
    Posted by Eric Oliver on January 9, 2008 at 10:44 pm
    Need some help.
    Working with a BM dual link pro HD card, and p2 720p 24PN footage.
    23.98 timebase in a DVCPRO HD 720p60 sequence…which blackmagic codec should i be using in audio/video settings?
    any help much appreciated.
    Kristian Lam replied 18 years, 8 months ago 3 Members · 4 Replies
  • Matthew Nelson
    January 10, 2008 at 6:25 pm
    Look in easy setups for the Blackmagic DVCPRO HD settings. There is a Blackmagic 720p 23.93 DVCPRO HD setting.
    I personally have never brought in P2 footage. I have only captured from a deck. It is my understanding that the footage will need to be wrapped in the blackmagic DVCPro HD codec to work with BM settings without needing to be rendered.
  • Kristian Lam
    January 10, 2008 at 10:07 pm
    There’s no such thing as a Blackmagic DVCPRO HD codec. That setups uses the Blackmagic hardware to output DVCPRO HD clips.
    regards
    Kristian Lam
    Blackmagic Design
  • Eric Oliver
    January 11, 2008 at 1:47 am
    what codec should i use then to view p2 720p60 w/ 23.98 timebase? Im using BM 720 59.94 8 bit right now…
  • Kristian Lam
    January 11, 2008 at 6:52 am
    Hi Oliver,
    That’s not a codec choice, it’s just the playback frequency and it is the correct choice.
    regards
    Kristian Lam
    Blackmagic Design
