Activity › Forums › Blackmagic Design › BlackMagic codec error – unplayable QTs
  • BlackMagic codec error – unplayable QTs
    Posted by Neil Ryan on August 21, 2007 at 12:12 am
    My designer made some QuickTimes a couple of months ago;
    used them in After Effects successfully; finished the job and had all his assets backed up on a firewire drive.
    This week, he has (had to) reload his computer (wiped HDD, new OS etc);
    We have put BlackMagic drivers on; we can play all other QTs with BlackMagic codecs except the ones he made a couple of months ago.
    They open in QuickTime with the ‘missing codec white screen’ and will play the audio, but not the vision.
    Here is the Info window:
    https://www.box.net/shared/static/c3m9d15245.jpg
    They will not play on two other machines, here including an old G4 which hasn’t had its BlackMagic codecs updated for ages, and usually plays everything.
    Any clues?
    Thanks for any help.
    Neil.
    Neil Ryan
    Post Production
    The Pod Multimedia
    http://www.the-pod.com.au
    Neil Ryan replied 19 years, 1 month ago 2 Members · 2 Replies
  • Kristian Lam
    August 21, 2007 at 2:32 am
    Hi Neil,
    The clips have been rendered to the Blackmagic 10-bit (DV10) codec. This is a legacy codec for Digital Voodoo support and is no longer included with the drivers as they are no longer in use.
    We have a tech note about this here:
    https://blackmagic-design.com/support/detail.asp?techID=33
    You’ll need to use the v5.7.2 driver which is the last installer to include to the DV10 codecs. I would recommend you render to the Blackmagic 10-bit codecs (not 10-bit (DV10)) codecs in the future.
    regards
    Kristian Lam
    Blackmagic Design
  • Neil Ryan
    August 21, 2007 at 2:55 am
    Thank you Kristian, that did the trick!
    Neil.
    Neil Ryan
    Post Production
    The Pod Multimedia
