Activity › Forums › Blackmagic Design › Blackmagic Cinema Camera – edit workflow using 12 bit RAW CinemaDNG
Alex Zvyk replied 12 years, 11 months ago 6 Members · 24 Replies
Rick Lang
June 16, 2012 at 2:32 pmSunil:
“What is this “rolling shutter” issue with BMD cinema camera?”Excellent explanation in Wikipedia so read that. It is something to be aware of when shooting motion and some cameras show less rolling shutter than others. Some have observed a jello effect when moving the camera but it is nit too severe on the BDCC apparently.
Rick Lang
iMac 27” 2.8GHz i7 16GB
Sunil Sanjan
June 23, 2012 at 2:51 pmThanks again Ric. I was just going through the lens. As per specifications we can use EF and ZE lenses for BMD Cinema camera ? What about Canon canon EF-S Lenses ? Are EF-S lens also compatible with BMD cinema camera. Also read that Full Frame cameras can only use EF lenses. APS-H sensors can only use EF lenses,EF-S lenses won’t work. APS-H are sensors with crop factor 1.3x. This means that they are 1.3x smaller than Full Frame sensors and therefore, crop some of your image.
Best Regards,
Sunil Sanjan -
Rick Lang
June 23, 2012 at 5:00 pmSunil, the BMCC takes EF-S lenses as well as EF lenses. The crop factor compared to full frame is about 2.3.
Rick Lang
Alex Zvyk
October 22, 2013 at 3:15 amHow about RAW 2 CF RAW. Converts raw DNGs to Cineform video raw, with audio.
