Activity Forums Blackmagic Design Blackmagic card and DVCPRO HD
  • Blackmagic card and DVCPRO HD
    Posted by Martin Stacey on March 6, 2006 at 12:33 pm
    i’ve recieved some quicktimes from a post house which are compressed in this way:
    DVCPRO HD vout 1080i60 imdc, 1920 x 1080
    is there any way to play this through a blackmagic card? is there any settings i should know about? at the moment i have put the project on blackmagic 10bit anamorphic. it’s going to be used for broadcast.
    any advice would be really appreciated.
    Martin Stacey replied 20 years, 6 months ago 2 Members · 6 Replies
  • Martin Stacey
    March 6, 2006 at 12:45 pm
    at the moment i’m having to recompress all the footage to 10bit black magic 720×576 anamorphic and it’s going to take around 10 hours. so if there’s anyway to avoid this it would be great.
  • Kristian Lam
    March 6, 2006 at 1:18 pm
    In Final Cut Pro, try the “Blackmagic HDTV 1080i59.94 – DVCPRO HD” Easy Setup (CTRL-Q). Then turn on down conversion in the DeckLink Preferences.
    regards
    Kristian Lam
    Blackmagic Design
  • Martin Stacey
    March 6, 2006 at 2:01 pm
    i’m using final cut 4.5 and it doesn’t have that easy set up.
    and i also don’t have that option in the decklink prefs.
    cheers for the help thou.
  • Martin Stacey
    March 6, 2006 at 2:14 pm
    right, i’ve installed the new decklink driver, and i have put it on the easy setup you mention and turned on down convertion but it still wont play out. i just get a still frame.
  • Martin Stacey
    March 6, 2006 at 2:22 pm
    cheers!
    it’s working now, i used the blackmagic 1080i 25hz one and it worked fine. is there any other settings i should be aware of?
  • Martin Stacey
    March 7, 2006 at 5:31 pm
    I’m also rendering out of after fx. It seems a bit stupid to render HD when it’s being broadcast SD. what sort of workflow does anyone suggest?
    so just to clarify:
    i have 1080i dvcpro footage. i will be combining this footage with after fx renders.
    delivery will be SD 720×576 anamorphic.
    At the moment i was going to edit in HD then just export a SD version for delivery. Would it just be better for me to re-render everything at SD?
    thanks
