Activity › Forums › Blackmagic Design › Blackmagic AVI output from Combustion – invalid?
  • Blackmagic AVI output from Combustion – invalid?
    Posted by Jeff Brown on September 27, 2006 at 1:27 pm
    I hope I am just having a “user error” issue, but I cannot get all codec choices for AVI output, and the AVIs I have made show up as corrupt in Combustion and Premiere Pro (2.x).
    The available outputs in Combustion for (BlackMagic) video for Windows are:
    BM 10-bit 4:2:2
    BM 10-bit 4:4:4
    BM HD 8-bit 4:2:2
    All of the above produce “corrupt” files reading into Combustion, and “unsupported or damaged” files reading into Premiere Pro.
    I need to output SD(D1) 8-bit 4:2:2.
    WinXP Pro
    Combustion 4.0.3
    DL 5.5 drivers (5.6 has more issues in my setup; have not tried 5.7 yet)
    Any help appreciated.
    -Jeff
    Margus Voll replied 20 years ago 2 Members · 2 Replies
  • Jeff Brown
    September 27, 2006 at 2:05 pm
    update: Just did a test with the 5.7 drivers. The same results, except MJPG AVI works well– quite well. That will be fine for my current projects. So thanks for the update! But I do wonder why BM SD 8bit 422 doesn’t appear in the list of codecs in Combustion, and why the 10-bit files are corrupt.
    -jeff
  • Margus Voll
    September 27, 2006 at 4:08 pm
    Hi.
    I had annother problem but not tested with latest drivers.
    What i had – output from combustion to avi files
    had some blockyness as compressed etc. specially with
    CG. I started to use quiqtime instead as it offered 8 and 10 bit uncompressed and did not make eny small boxes etc on my CG and
    it worker with Prem Pro 1.5
    I’ll check this out tomorrow how it looks now afted 5.7 update.
    Margus
    https://iconstudios.eu
