Activity Forums Adobe Premiere Pro Blackmagic and Premiere Pro issue
  • Blackmagic and Premiere Pro issue
    Posted by Brad Williams on May 14, 2012 at 2:50 am
    I am a Final Cut Pro user moving over to Premiere Pro CS5. I use a Blackmagic Decklink Extreme 3-D card. I want to capture in 720 p 59.94. I have tried to set all the capture settings correctly and it will not capture. Also inputting video files in will not play the audio out. Any ideas? I am on a Mac Pro running 10.6.7 I believe.
    Chris Borjis replied 14 years, 4 months ago 2 Members · 1 Reply
  • Chris Borjis
    May 14, 2012 at 7:33 pm
    you have to have 10.6.8 and quicktime 7.6 minimum.
    maybe not the cause, but you should have at least this installed.
    are you running black magic drivers 9.5.1?
