Activity › Forums › Blackmagic Design › BlackMagic and HD realtime!?!
  • BlackMagic and HD realtime!?!
    Posted by Ndamir on April 22, 2005 at 7:46 am
    I have G5/2.0DP, 4GB RAM, xServe RAID and BlackMagic HD card.
    If I put 1 stream of HD video in my sequence everything is OK no rendering required. But if I apply transition or filter I need to render. Not one filter or transition in FCP is bolded (realtime) while I work with HD material.
    I tried FCP rendering engine and BlackMagic rendering engine with no luck.
    Is this normal!?!
    Thanks in advance!
    Damir Nazor
    Ndamir replied 21 years, 5 months ago 2 Members · 2 Replies
  • Luke Maslen
    April 22, 2005 at 7:53 am
    Hi Damir,
    You’ll see plenty of RT on a DVCPRO HD timeline. If you have an uncompressed 8-bit HD timeline, set the effect handling to Blackmagic HD and you will get 3-way color correction and a number of image control effects. I don’t think you will get any RT effects in 10-bit HD at the moment although we’ll look at that again and see if it is now possible.
    Regards,
    Luke Maslen
    Blackmagic Design
  • Ndamir
    April 22, 2005 at 11:47 am
    Thank you, o thank you, o mighty one!!! 🙂
    What do you meen by if it’s now possible!?!
    Best Regards,
    Damir Nazor
