Activity Forums Blackmagic Design Blackmagic 9.5.1 driver for Decklink SDI seems to crash Premiere Pro CS6 on Mac under Lion 10.7.4
  • Blackmagic 9.5.1 driver for Decklink SDI seems to crash Premiere Pro CS6 on Mac under Lion 10.7.4
    Posted by Helmut Kobler on May 12, 2012 at 1:07 am
    I have a clean install of Lion, and installed CS6. I downloaded the latest Blackmagic driver, restarted, and then went to System Preferences to set the Blackmagic preferences pane for 1080 23.98. Then launched Premiere Pro.
    I go to Premiere’s Preferences, choose the Playback tab, and then driver to select Blackmagic Playback under the Video Device box. I can select it, but as soon as I click OK, I get a pop-up dialog in Premiere saying:
    “Sorry, a series error has occurred that requires Adobe Premiere Pro to shut down. We will attempt to save your current project.” Premiere then hangs, and I have to do a force quit to release it from its pain.
    Anyone else having this issue?
    The Decklink driver works fine in FCP X.
    Documentary Camera in Los Angeles
    http://www.lacameraman.com
    David Willey replied 14 years, 2 months ago 3 Members · 4 Replies
  • Myles Conti
    May 18, 2012 at 7:04 am
    I too have been experiencing similar problems, and am working with a Blackmagic card. I’ve been trying to troubleshoot – last night I thought it had something to do with Red Giant colour look plugin, as things improved after I removed these filters, but then this morning Premiere wouldn’t run for more than a minute without crashing with these filters removed.
    AE seems to work fine, using blackmagic playback.
    I haven’t tested the project with blackmagic playback turned off – I’ll give this a go and let you know the results.
    I’ve been receiving the same error message
    Ok – update, I was using driver 9.5 – now have upgraded to 9.5.1, it’s a little hard to tell, but it seems that the project file that I was having the problems with continues to be a problem – will let me work for a little while, then crash. I’ve started a fresh project and imported a range of footage, including some from my problem project, and so far so good. I get playback fine on external monitor, and haven’t yet crashed.
    Have you tried a new project? or are you continuing to experience problems with the same one? I kept having problems even when using copies of project. I also started a new project and pulled in old sequence, and the problems began again.
    Turning blackmagic playback off – still gave me problems in my “problem” project.
    My new project seems to be working for now with blackmagic playback both on and off.
    Hope this helps – I’d be keen to hear of your progress.
    Myles Conti
    Director Conti Bros Films
    http://www.contibrosfilms.com
  • Myles Conti
    May 18, 2012 at 7:07 am
    Turning blackmagic playback off – still gave me problems in my “perhaps corrupted” project.
    Ok – ANOTHER UPDATE – As soon as I finished typing above, I jumped into Premiere, turned off blackmagic output, and now project has locked up. 🙁
    Myles Conti
  • Myles Conti
    May 28, 2012 at 11:30 pm
    After a couple of troublesome weeks – I’ve realised my problems stem from a dodgy NVIDIA GTX 285 card that I installed, and not the deckling drivers. If anyone is reading this, be very careful if purchasing a GTX 285 for mac, as there are reports of a number of people tricking up cheap PC cards, so as they appear to be a GTX 285 for Mac.
    Now, I’m in the process of trying to get my money back 🙁
    Myles Conti
  • David Willey
    July 24, 2012 at 9:43 pm
    Did you ever figure out your issue? I have the same issue with a MacPro, Decklink SDI card and a Quadro 4000 video card. Lion just seems doggy and every time a click from source to the timeline a get a loud buzz. Kind of annoying while editing 🙂 I also have the GenArts Sapphire plug-ine set.
    Thanks fellow bovine friends,
    David
    Meredith Integrated Marketing
    Des Moines, IA
