Activity › Forums › Apple Final Cut Pro Legacy › Blackburst/Sync generator?
Posted by Christopher Grosso on June 2, 2008 at 5:53 pmI had to buy a BetaSP deck for some broadcast work we’re doing. What do you guys use to feed the reference signal to your Beta decks? Recording and playing works fine, monitoring is only showing half the picture without reference. All suggestions are appreciated.
David Bogie replied 18 years, 3 months ago 5 Members · 5 Replies -
Steve Eisen
June 2, 2008 at 6:23 pmI run my Beta SP deck through a Decklink SP. Reference is not needed. Same goes for AJA IOLA.
Are you using a capture card? How is your deck hooked up?
Steve Eisen
Eisen Video Productions
Board of Directors
Chicago Final Cut Pro Users Group -
Christopher Grosso
June 2, 2008 at 6:36 pmRight now the Beta get’s an S-Video signal from a Canopus ADVC 100. I just ordered a Blackmagic Intensity Pro card that will allow the Beta to get Component.
Produce | Shoot | Edit
Take Two Visual Media
https://www.take2vm.com -
Arnie Schlissel
June 2, 2008 at 6:57 pmThe best value for a sync generator right now is an Aja Gen10. It will cover all of your SD & HD needs, for around $400.
Arnie
Post production is not an afterthought!
https://www.arniepix.com/ -
Chris Poisson
June 2, 2008 at 8:11 pmI got one of those Horita boxes for just over $300.
Have a wonderful day.
David Bogie
June 2, 2008 at 8:14 pmHorita sells the rock bottom unit, about $250, look for PSBG for portable black burst generator.
However, almost ANY coherent video signal will satisfy most of the BetaCam decks. Composite video should be usable without blackburst or another genlock signal but you would not be able to take the untimed signal into a switcher. Check the manual carefully for possible reference inputs, you may already have something laying around that will do the job. Also, if you have a used electronics shop in your market area, they may have something dirt cheap. Also might be worth calling anyone you know in the engineering functions at any tv or cable outfits. Sync-source and house-source electronics get replaced regularly but the old gear is rarely junked.
bogiesan
