Activity › Forums › Apple Final Cut Pro Legacy › Blackburst generator
Posted by Scott Davis on June 13, 2010 at 4:24 pmI am ingesting Beta material through a Kona 3 and upconverting to ProRess 422 1820x1080i. Do I need a tri-synch blackburst generator or can I use a “standard” one? I have access to a little Horito unit, not at the studio so forget the model number, but I am positive that it is not tri-synch.
John Fishback replied 15 years, 11 months ago 5 Members · 6 Replies -
John Pale
June 13, 2010 at 5:49 pmYou only need tri level sync to master to 23.98. If you are working 1080i/59.94 (29.97fps) you can just use a “regular” black generator.
John Fishback
June 13, 2010 at 6:07 pmAFAIK, standard black burst will work for 29.97 and, I guess, 59.94. Tri-level sync comes into play for 23.976 material. The AJA Gen10 can produce both black burst and tri-level aync at an excellent price. Many people suggest looping the ref video to the composite video in of a BVW1800. I’ve not heard if it helps with other Beta decks. If you search for Bob Zelin and Gen10, you’ll find more specific info from someone who really knows tech.
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)Pro Tools HD w SYNC IO & 192 Digital I/O, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
Bob Zelin
June 13, 2010 at 11:21 pmif you have the Horita BSG-50 (not BG-50), it will work just fine for your application, as long as you have the TERMINATION switches set to ON on your VTR. If your Beta VTR (and your AJA kona breakout box looping input) are not terminated (75 ohm on), then the horita will appear to not work. And if you do not set your AJA Control Panel CONTROL tab to EXT REF (or REF Vid – whatever it’s called) it will not work.
Bob Zelin
Scott Davis
June 13, 2010 at 11:35 pm -
Deleted User
June 15, 2010 at 9:51 pmPardon me for a slight hi-jack of this thread but can cards like the Konas and Matrox boxes run without burst? What are the implications?
Lee
John Fishback
June 16, 2010 at 9:28 pmIf you capture or layback to tape, not having ref video will lead to a host of potential problems. Even without going to or from tape, lack of ref video can cause audio issues like crackling and popping.
John
