Activity › Forums › Apple Final Cut Pro Legacy › black screen question
Posted by Kelly Armstrong on September 16, 2012 at 2:50 pmHello,
I have to re-edit a music video however the footage reveals that the singer is in front of a black screen.
The client wants outer-space to be composited behind her but i’ve never worked with black screen before and am completely unsure on what to do.
Mark Suszko replied 14 years ago 6 Members · 8 Replies -
Rafael Amador
September 16, 2012 at 3:06 pm[kelly armstrong] “I have to re-edit a music video however the footage reveals that the singer is in front of a black screen.
The client wants outer-space to be composited behind her but i’ve never worked with black screen before and am completely unsure on what to do.”
Black screen or has already been keyed an Alpha channel?
Which codec is the footage?
Anyway, put some picture on layer 1 and the video in layer 2. See if has transparence.
rafael -
Hariharan Swaminathan
September 16, 2012 at 3:10 pmYou really don’t have to be an expert to work with chroma key as long as footage has a background with clean flat lighting. It should be either green or blue. The reason for that is, usually subject’s costume will not have those colors on them so software won’t take portion of it.
So I don’t believe in just green or blue. Black should be fine, but pls make sure you dont’ key out any part of the singer if she happens to have black color in her dress.
If that happens to be the case, you need to mask her first and then start keying. It’s a very tedious job since this is a music video i assume the motion will be lot. Motion tracking requires lot of keyframes.
If all is ruled out, keyout is just a matter of clicking and a little bit of color tweaking to fine tune it. In final cut pro you can use chroma keyer, or dv matte etc plugins. There are many out there.
If you have after effects it has a inbuilt plugin which is pretty straight forward and do a wonderful job.
Here is a video for final cut keyout: https://www.youtube.com/watch?v=5Zt8EYaGIeM
I did one myself recently for my company. I did this with home depot lights and it worked very well. Here is the link if incase you might be interested
https://vimeo.com/39950085| Hariharan Swaminathan |
photographer | film maker
http://www.filmmaker.me
http://www.vimeo.com/ihariharan
http://www.youtube.com/ihariharanSome contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Kelly Armstrong
September 16, 2012 at 8:25 pmBasically the artist was shot in front of a black sheet, stretched tightly.
I’ve chroma keyed in Final Cut before, which has the clear green or blue option.
However, looking at it now there is no black option, or black gradient to select. I’ve tried changing the composite modes but that doesn’t help either.
Any advice?
Kelly Armstrong
September 16, 2012 at 9:31 pmThat’s what I thought.
I do know after effects so I might have to do something in there but I don’t really have the time.
The head on shot is pretty basic, so I guess my best bet is to mask around the artist while she sings, and put my background behind her?
Kelly Armstrong
September 16, 2012 at 9:46 pmIs there a way to turn the black into an alpha channel? I only have two days to edit the entire video so roto brushing is just not an option unfortunately…
Bret Williams
September 17, 2012 at 1:53 amHave you tried a screen composite mode? If its zero black (and a sheet won’t be) then it’ll work well.
Also try a basic luma key.
Michael Gissing
September 17, 2012 at 5:24 am+1 for Luma key. Unlikely to work well without matteing as he talent is likely to have something that is black.
There is no black option in chroma key as black is the absence of both luma and chroma.
Mark Suszko
September 17, 2012 at 1:57 pmTry a luma key on it, also play with the blending/composite modes. If you’re going to replace the black with more black (space), a rough matte might get you there. You can’t chromakey black, but you can use the extract tool from AE or photoshop on it. You might also try applying a batch action to an image stack in photoshop.
The director/producer for this job needs a dope slap on the back of their head: they really didn’t know what they were asking of you when they shot this in this way.
