Activity Forums Zaxwerks Black Screen issues during preview
  • Black Screen issues during preview
    Posted by Evan Seccombe on January 19, 2006 at 7:02 am
    So all of a sudden zaxwerks cant be previewed in AE when i switch the quality swatch to Best. Draft works, and renders just fine. but switching to Best just brings up a black screen, and i cant even test the render within Zaxwerks itself.
    Evan Seccombe replied 20 years, 8 months ago 2 Members · 3 Replies
  • Jon Okerstrom
    January 20, 2006 at 1:23 am
    Hi FireBert,
    Here’s a totally off the wall guess.
    Take a look at the Invig check box for use comp lights. If it’s checked and you don’t have any comp lights, because you’re trying to use Invig’s own lights, you might get the black screen effect in best quality rendering.
    Does this help?
    Jon
  • Evan Seccombe
    January 20, 2006 at 8:37 pm
    no thats not even the problem. i mean that it wont render period. i click ram preview and then for a breif fraction of a second it pauses then stops. no rendering is done period, and zaxwerks wont let me test the render in the plugin. any help?
  • Evan Seccombe
    January 20, 2006 at 9:09 pm
    well i figured out what it was. in case anyone needs this advice when they encounter this problem, simply just go into the invigorator plugin, select all of your objects in the scene, and then in the object menu click reload below where the file’s path.
