Activity › Forums › Adobe After Effects › black outline around chroma keyed
Posted by Susan Lan on April 29, 2016 at 3:00 pmOnced I applied the chroma key, ¿how can I remove the black colour that is around the girl, as an aura?
I tried with “remove color matting2 but does fix that, look, help please
https://i.imgur.com/XAsFSOa.jpgSusan Lan replied 10 years, 4 months ago 2 Members · 5 Replies -
Wallace Adrian d’alessio
May 1, 2016 at 2:12 amDid you try the spill adjustment?
Adrian D\’Alessio aka; Fluxstringer
fluxstringer@gmail.com
https://www.facebook.com/FluxStringer
https://www.linkedin.com/in/fluxstreamcommunicationshttps://twitter.com/FluxStringer
https://mog.com/FluxMuse -
Susan Lan
May 1, 2016 at 2:32 amyes, I tried it, and the photo I atached is the result after:
keylight+spill slayer (bias to 65) + alpha matte to make the Light Wrap (I mean, this: https://www.youtube.com/watch?v=nJENj3thMLImust I aplly “a filter” in all the girl, now? or what last step do the professional?
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
May 1, 2016 at 4:20 pmI do not have your SpillSlayer.
But try this
In a composition with your Background and foreground layers
any your key layer if separate ( as that becomes your keying mask.
On the mask layer apply an opacity reduction. ( to suit your eye).On the foreground layer apply a levels correction effect. set output white ( lower slider display) to set foreground to taste ) set the blacks also to best match your vision of the shot.
Adjust gamma ( middle triangle, upper slider display) to a level where you believe it best serves focusing the audience on the talent.Hit Ctrl + Alt + y to create an adjustment layer. Rename the layer color correction or CC.
To this you can apply you favorite color correction effect. A photo filter, a gradient anything you like.
Apply an opacity adjustment to the CC layer to best match the look you are going for.If the result still looks like it has too sharp an edge;
Try one or more;A. Try adjusting the spill or other edge related settings in your key effect.
B. Try adding a very slight box blur to your keying mask.
C.Try adding a different blend mode.
As always take notes before and after so you know where you made changes and the result. Include what you did or did not like about each change.
You will find the same methods on different footage give different results. Writing down why you think the results are different can add to your understanding of digital imaging in the future.
As a side note;
____________________________________________
Before you startIf the BG and FG footage were not shot with the same camera
or if they are not even the same aspect -etc. Learn how to match grain etc. To make your chroma keyed shots look more like one single shot.Adrian D\’Alessio aka; Fluxstringer
May 1, 2016 at 4:23 pmI do not have your SpillSlayer.
But try this
As a side note;
or if they are not even the same aspect -etc. Learn how to match grain etc. To make your chroma keyed shots look more like one single shot.Also
________________________________________Practicing compositing with the selection tools in Photoshop will help you get a feel for mask edges and the various ways of dealing with them. The refine edge panel and trying all of its settings and modes will show you the way.
