Activity Forums Adobe Premiere Pro Black Magic Deck Link card and CS6
  • Black Magic Deck Link card and CS6
    Posted by Phil Hawes on February 4, 2013 at 5:16 pm
    Hello,
    Is anyone out there using a BMD Deck Link card with Premiere CS6?
    How is it working out?
    I need a basic HD-SDI output for color correction to replace my Kona LHe that AJA has dropped support for.
    The BMD card also interests me for working with Resolve, I’m not expecting to support Speedgrade at this point.
    Phil
    Evan Schafer replied 13 years, 7 months ago 4 Members · 7 Replies
  • 7 Replies
  • Chris Borjis
    February 4, 2013 at 5:32 pm
    I am.
    It’s working well.
    Having an odd issue with black levels, but only
    on SD analog output.
  • Phil Hawes
    February 4, 2013 at 8:28 pm
    That’s good to hear.
    I’m considering the basic Decklink SDI model.
    I’m just doing HD-SDI output.
  • Peter Berthet
    February 4, 2013 at 9:37 pm
    We’re running 6 suites here with blackmagic and CS6 and it works great 🙂
    – Pete
  • Phil Hawes
    February 4, 2013 at 10:24 pm
    Thanks, that’s good to hear.
    I don’t have a Tri-Level sync.
    Do you know if the Deck Link can generate sync without an external reference?
    This is how I output a signal from my AJA card to the Sony PVM monitor with the Ross SDI to Component converter card. Just with Genlock in FreeRun in the AJA control panel. I assume the control panel on the Deck Link has this function?
  • Peter Berthet
    February 4, 2013 at 11:05 pm
    off the top of my head im pretty sure you can generate internal sync off the BMD
    – Pete
  • Chris Borjis
    February 5, 2013 at 6:51 pm
    agreed, no need for an external generator for monitoring.
    I monitor 24 frame often. The card just switches the monitor
    to the 48hz mode.
  • Evan Schafer
    February 13, 2013 at 2:35 pm
    For those of you having success running PP CS6 with BlackMagic Decklink, would you mind listing the configuration you are using successfully?
    Version of OS, Decklink Software version, specific BMD card, etc.
    We have had many playback issues with our configuration causing us to drop PP CS6 use for now.
