Activity Forums Apple Motion Black Lower Thirds & down stream keying
  • Black Lower Thirds & down stream keying
    Posted by Greg Davis on February 24, 2012 at 4:30 pm
    I have created a lower third in motion five that contains black. When I Broadcast thru DSK on my switcher all of the black is keyed out and transparent. Does any have a solution for this problem.
    Mark Spencer replied 14 years, 6 months ago 2 Members · 3 Replies
  • Mark Spencer
    February 24, 2012 at 4:55 pm
    Edit > Project Properties. Change the Background from Transparent to Solid.
    Mark Spencer
    Freelance Producer/Editor/Motion Graphics Artist
    Apple-certified Master Trainer
    Author, Motion 4 from Peachpit Press
    https://www.applemotion.net
  • Greg Davis
    February 24, 2012 at 6:20 pm
    Changing that did help, some of the black did come back, but some of the black is keying out. I am exporting from motion 5 and running the QT video thru (On the Air Video) and into my switcher (Panisonic HS400). It my be a setting in my switcher. When I create graphics in On the Air CG. It also keys out everthing black. Please let me know any suggestions you have.
  • Mark Spencer
    February 24, 2012 at 6:37 pm
    Are you exporting in a format that supports an alpha channel, like Animation or ProRes 4444? And does your switcher support the codec you are using?
    Mark Spencer
