Activity › Forums › Apple Final Cut Pro Legacy › Black line issue in HD footage to SD DVD
  • Black line issue in HD footage to SD DVD
    Posted by Matt Surf on January 3, 2012 at 9:35 am
    Hi there,
    I recently shot a massage film against a white background and I’m having difficulties compressing the footage for use on a DVD.
    The film was shot in full HD using a Canon EOS 550D then compressed using Pro Res and edited out through FCP7. So far so good.
    However, when I go through the usual Compressor settings for DVD Best Quality 90 minutes I get jagged edges on the lips of the subject when she talks plus other jagged issues.
    So, I did a bit of surfing and created a new Compressor setting with Frame Controls set to Resize Filters: Better / Output Fields: Same as Source and Deinterlace: Better and Adaptive Details is ticked.
    However, this option is creating faint black/grey horizontal lines across the white background of my encoded film.
    Any help so I can get the best settings to stop either of these happening would be greatly appreciated. For info, both versions have been used on a Sony Blu Ray player on a HD Ready LCD TV which I assumes is trying to upscale the quality.
    I also tried using Larry Jordan’s settings and converted into Pro Res 422 HQ first but this just created a version where half the screen was black and the other section was weird pinks and green flashes (bizarre).
    Thanks in advance for any help
    Matt
    Chris Tompkins replied 14 years, 9 months ago 2 Members · 3 Replies
  • Chris Tompkins
    January 3, 2012 at 11:56 pm
    You don’t mention how long the video is.
    But, bluray upres to HDTV will not look the best.
    Have you video the SD dvd on a DVD player to a SD tv?
    Have you ticked up the data rate for more quality if you have the room.
    Chris Tompkins
    Video Atlanta LLC
  • Matt Surf
    January 4, 2012 at 1:22 pm
    Hi Chris,
    The film is around 20 minutes long so pretty lengthy. So far, I’ve only played the SDVD on a Blu Ray player so yeah, will auto upscale. You’re right though, perhaps I should also try it on a normal DVD player.
  • Chris Tompkins
    January 4, 2012 at 2:24 pm
    Ya u have a 90min preset w/20 min vid
    Up the data
    Chris Tompkins
    Video Atlanta LLC
