Activity Forums Adobe Premiere Pro Black line in export!!
  • Black line in export!!
    Posted by Bob Dobson on January 19, 2012 at 3:34 pm
    Hi All,
    I’ve got a bit of a problem with a black line appearing down the side of the exported .mov file when I export it.
    The footage is shot on a Kodak Zi8 in 1280 x 720 and the project is 720 x 576 and the export is 1024 x 576 .mov with sorensen compressor 1.0 square pixel as I want to play it online. It is 35 mins long and took 16 hours to export.
    I guess the problem is that the project settings don’t match the footage settings as the titles at either end are fine.
    The strange thing is I made a smaller .mov clip (duration 1.30min) using the same settings with the same footage and there was no black line.
    I’d like to
    1) Export it without a black line showing up
    2) Speed up the export process (!?!)
    3) Know if there is a way to take a sequence from one project and put it into another as I can’t find a way to change the project settings. I’ve tried to do this and seemed to lose all the transitions and sounds levels.
    Any help is greatly appreciated.
    Bob
    Bob Dobson replied 14 years, 8 months ago 2 Members · 2 Replies
  • Ann Bens
    January 19, 2012 at 3:42 pm
    What if you export to 1050×576 square pixel?
    Adobe Certified Expert Premiere Pro
    Adobe Community Professional
  • Bob Dobson
    January 19, 2012 at 4:14 pm
    I haven’t tried that but I will – thanks.
