Activity › Forums › Apple Final Cut Pro Legacy › black line
black line
Posted by Matthew Grimes on July 3, 2007 at 3:30 pmcan anyone help me out:
i have this black line showing up in all my projects
just capture from dv tape shot at 29.97 through a hvx200when i create a timeline using ntsc 48k the line is there
i can see it when i captureusing a fcp 5.1.4
capturing using firewire basic
view images here
http://www.dev-ein.com/fcp/fcp.png
http://www.dev-ein.com/fcp/ the root has a couple other png’s in there to view
Jeremy Garchow replied 19 years, 2 months ago 6 Members · 14 Replies -
Jeremy Garchow
July 3, 2007 at 3:48 pmThat won’t show up in overscan, and since you are shooting green, you can crop the top.
Jeremy
Matthew Grimes
July 3, 2007 at 3:54 pmit shows up everywhere!
https://dev-ein.com/fcp/c2_v3.png
you can make it out across the top their
this was just a still taken from the timeline -
Shane Ross
July 3, 2007 at 4:17 pmStandard Def video is 720×486. DV video is 720×480…6 lines of information missing. What you are seeing is the missing 6 lines of video. This is WELL into the overscan of TVs, and will never be seen outside of FCP or a QT movie of the project.
Shane
Littlefrog Post
http://www.lfhd.net -
Matthew Grimes
July 3, 2007 at 4:34 pm -
Jeremy Garchow
July 3, 2007 at 4:45 pmShane explained it perfectly. It’s video, and how it works.
if you don’t want to see it, crop. But remember, it will not show up on a tv.
Jeremy
Shane Ross
July 3, 2007 at 4:47 pm[lear2006] “unfortunately its on qt exports as well”
As I said it would. But your TV and EVERY other TV in the country will hide it. You lose about 5% of your image on the outer edges due to the plastic that holds the screens in place. This is why you have TV SAFE guides…to show you what is guarenteed to be seen by all TVs.
Shane
Littlefrog Post
Matthew Grimes
July 3, 2007 at 4:55 pmwell does anyone else have this?
this is also going to be flv’ed so will cropping hurt the quality? -
Jeremy Garchow
July 3, 2007 at 4:57 pmI crop out the crap on all my web/flash movies. That little line is nothing.
Don’t worry about it, you are just fine.
Jeremy
Stace Carter
July 3, 2007 at 5:00 pm“But your TV and EVERY other TV in the country will hide it.”…
Yes and no. I think this whole “title safe” thing is going away, with the advent of LCDs and Plasmas. And computers as video playback devices. The only place you won’t see it is on a CRT, so you’d be wise to crop it, just to be… safe.
Any other thoughts on title-safe going away? I’ve been nailed on this now twice, fortunately (or not) the projects weren’t going to broadcast, but I’d think I was in the clear until I played a test DVD back on my laptop or home LCD.
Shane Ross
July 3, 2007 at 5:01 pm
