Activity Forums AJA Video Systems Black Levels and AE renders
  • Black Levels and AE renders
    Posted by David Battistella on September 9, 2005 at 4:50 pm
    Hi Gang,
    I have noticed that Movies rendered out of AE to the annimation codec come into KONA with setup. What should be black (0 on FCP scopes) is actually sitting at around 10 units.
    Is this an AE render setting or how the KONA or FCP sets the blacks on these imports?
    David
    Gary Adcock replied 20 years, 12 months ago 2 Members · 2 Replies
  • David Battistella
    September 9, 2005 at 4:54 pm
    The annimation clip with the annimation codec does not show up in the viewer on import
    Easy setup
    KONA 2-NTSC 8Bit to DVCPRO 50
    David
  • Gary Adcock
    September 9, 2005 at 8:38 pm
    [David Battistella] “I have noticed that Movies rendered out of AE to the annimation codec come into KONA with setup. What should be black (0 on FCP scopes) is actually sitting at around 10 units. Is this an AE render setting or how the KONA or FCP sets the blacks on these imports?”
    Since the animation codec is not a “Kona” proprietary codec, it must be something else.
    Most likely it is at 7.5 IRE on the FCP scopes, as it should be according to the RGB – YUV conversion LUT’s used in Core Video for NTSC video.
    That’s why there is a 10 bit Kona RGB codec.
    From IBC
    Gary Adcock
    Studio37
    HD and Film Consultation
    Chicago, IL
