Activity Forums Adobe After Effects Black levels 0 IRE vs 7.5 IRE
  • Black levels 0 IRE vs 7.5 IRE
    Posted by Stephen Lee on January 20, 2006 at 1:27 pm
    Hi…
    We recently switched from DVCPro to XDCAM. The black levels on the animations I make on AE 6.0 come in at 0 IRE and I need them to be 7.5 IRE. Has anyone run into this issue? Have suggestions?
    Steve Roberts replied 20 years, 8 months ago 3 Members · 2 Replies
  • Greg Quitiquit
    January 20, 2006 at 7:23 pm
    This is what I do:
    1) Create an adjustment layer as the top layer in your comp.
    2) Select EFFECT>ADJUST>LEVELS from the menu.
    3) In the Effects control window, set Output Black to 16 and Output White to 245.
    Depending on what this ends up looking like, I may also adjust the input levels.
    Or you could check and adjust each of your elements the same way individually.
    Greg Quitiquit
  • Steve Roberts
    January 20, 2006 at 7:26 pm
    [Greg Quitiquit] “set Output Black to 16 and Output White to 245”
    You don’t set the output white to 235?
