Activity Forums Apple Final Cut Pro Legacy Black Horizontal Bars Across Log and Capture Footage
  • Black Horizontal Bars Across Log and Capture Footage
    Posted by Elizabeth Wallace on January 7, 2011 at 9:27 pm
    Hi All,
    I’m having some trouble with my Log and Capture window in Final Cut Pro 3. I am using a basic DV tape deck (which was working fine just yesterday and is fully hooked up via firewire), and a mini DV tape. In the Log and Capture window, my footage displays with thick, black bars running horizontally across the frame (about five of them). They appear over every tape that I try to put in right now. My capture presets are all set to DV NTSC, and I haven’t changed any settings since the tape deck was working fine just yesterday.
    Any suggestions?
    ~Elizabeth
    Curt Lafurney replied 13 years, 2 months ago 6 Members · 7 Replies
  • 7 Replies
  • Rafael Amador
    January 7, 2011 at 10:00 pm
    Hi Elizabeth,
    By any chance are you on Snow leopard, and you haven’t QT 7 installed?
    If so, do it.
    QT 7 is on the SL Installation Disk > Extras.
    Rafael
    http://www.nagavideo.com
  • Elizabeth Wallace
    January 7, 2011 at 10:06 pm
    I’m running Mac OS X and I have both Quicktime 7 and Quicktime Pro 10 installed. The funny thing is, while I was waiting for a thread reply, it started working and then stopped again. It’s done this in the past, and it seems totally spontaneous. Any ideas what might cause the spontaneity of the problem?
    ~Elizabeth
  • Tyler Leisher
    January 8, 2011 at 1:19 am
    Are you setting up your project differently? If you setup a project with a specific resolution and then import footage that doesn’t match that it will add those bars.
    It is adding them to compensate for the aspect ratio.
    What camera are you using, how are you ingesting it (Firewire?) and what project settings are you using?
  • Neal Broffman
    January 8, 2011 at 3:38 am
    Perhaps dirty heads on the DV deck. Have you run a head cleaning tape through it?
    Neal Broffman
    One Production Place, Atlanta, GA
    “Voices of Freedom”, Special Jury winner for Fall 2008 CINE Awards produced for the High Museum of Art in Atlanta as part of a major exhibition of vintage Civil Rights Movement photographs, “Road To Freedom”. Currently on display at The Bronx Museum (through August) after having been on exhibition at the Field Musuem in Chicago, The Skirball Cultural Center in LA and The Smithsonian in DC.
  • Walter Biscardi
    January 8, 2011 at 11:37 am
    If you have a head cleaning tape, run it through the deck. Sounds like you might have dirty heads.
    Walter Biscardi, Jr.
    Editor, Colorist, Director, Writer, Consultant, Author, Chef.
    HD Post and Production
    Biscardi Creative Media
    “Foul Water, Fiery Serpent” Winner, Best Documentary, LA Reel Film Festival.
    Blog Twitter Facebook
  • Curt Lafurney
    June 14, 2013 at 10:05 pm
    Try cleaning the heads on your deck
  • Curt Lafurney
    June 14, 2013 at 10:08 pm
    Black bars like that are usually something gumming up the heads. Old tape for example will do this a lot
