Activity Forums Apple Final Cut Pro Legacy Black frames between clips on export
  • Black frames between clips on export
    Posted by Ben Hartley on October 22, 2013 at 8:24 am
    I am getting black frames that flicker between each clip after export, which is very annoying indeed. Any ideas why this is happening?
    If it looks good, look at it.
    Nick Meyers replied 12 years, 11 months ago 3 Members · 2 Replies
  • Neil Patience
    October 22, 2013 at 9:33 am
    Hi Ben
    My first though is that you may have edited your sequence using H264 files.
    Can you give details as to your format and codec etc.
    best wishes
    Neil
    http://www.patience.tv
    8 Core MacPro, Kona 3, Tangent Wave, Mackie Universal Symphony 6.5 or MC V 7 with Symphony option. FCP7, Color, Media creation and conversion. Adobe Encore DVD creation and authoring.
    i7 2.7 Gig MBP (non retina) 16Gigs Ram Blackmagic Monitor Mini Symphony 6.5 or MC v7 with Symphony option FCP7
    7TB raid 5 fibre storage.
  • Nick Meyers
    October 23, 2013 at 1:27 am
    you can get black frames between clips in FCP if you edit in a sequence of one frame rate,
    then copy / paste into a sequence of another frame rate.
    it might also happen if you try to change the frame rate on export by choosing a different setting.
    nick
