Activity Forums Adobe After Effects Black Drop Frame Issue
  • Black Drop Frame Issue
    Posted by Lizzie Turner on April 7, 2010 at 3:13 pm
    Im having trouble with camera movement causing a black frame.
    Heres a screen shot because the I have no idea why its happening
    https://img179.imageshack.us/img179/6617/blackframeissue.jpg
    As you can see I have 3 keyframes for the camera dolly position. Before adding the third keyframe there is no issue, but after adding it, no matter what value i change i get a black frame between the second and third keyframe.
    I dont understand why this is happening as ‘bits’ and ‘pre comp 1’ should be visable.
    I have have tried taking easy ease away but that just moved the black frame.
    If anyone could help it would be great – this is driving me crazy!
    Lizzie
    Tudor “ted” jelescu replied 16 years, 5 months ago 2 Members · 1 Reply
  • Tudor “ted” jelescu
    April 7, 2010 at 4:53 pm
    since you have a 3d comp it may just be that you get a black frame when the camera passes through a plane in 3d space.
