Activity Forums Maxon Cinema 4D “Black dots”
  • “Black dots”
    Posted by Mert Yagmur on October 31, 2020 at 8:08 pm
    Hello,
    (I am still getting used to cinema 4d)
    After I copied and placed a groupe of objects in a building model, black dots have appeared outside of the building and I can’t find a way to interact with them.
    Various post mention black dots appearing in rendering processes and lighting settings. I have indeed accidentally added a lighting object while operating on my objects but removed it immediately afterwards.
    I have seared for any way to remove them but noting I try is working on them.
    Can someone of you provide any advice on this issue. I would appreciate any hint of direction or solution, because it took a long time of work till now and would rather not restart, if possible 🙁
    Thanks you
    Andy Kiernan replied 5 years, 10 months ago 2 Members · 1 Reply
  • Andy Kiernan
    November 2, 2020 at 10:59 am
    They are, I think, the anchor points of various objects in your scene, most likely nulls. You can turn off the display of them in each of their settings in the AM. But they don’t render by default so perhaps just ignore them?
