Activity Forums Boris FX Black cross over Boris renders
  • Black cross over Boris renders
    Posted by Jamie Hancock on April 27, 2006 at 6:23 pm
    I’ve been putting some Lucas-style linear wipes onto a project using Boris in Prem Pro 1.5, and everything has worked fine until I last loaded the project. Now, all the Boris fx have a black X across the screen. The fx are still there and the renders are apparently ok , as the indication line across the top (forget how to refer to it, sorry) is green rather than red across the board.
    Would anyone have any idea as to why this may be happening? A render/preview file issue, perhaps?
    J . . .
    Peter Mcauley replied 20 years, 4 months ago 3 Members · 3 Replies
  • Stephen L. noe
    April 28, 2006 at 12:05 am
    That usually means your using a demo version of red and your trial period has expired. Open up the Help menu in the stand alone engine. Now click on the “Register Boris Red” menu item and go through the steps or reinstall using your serial number found on the sleeve of your boris red disk.
  • Jamie Hancock
    May 1, 2006 at 10:14 am
    I’ve tried reinstalling, but to no avail, and I’m pretty sure it’s not the demo version. I’ve a horrible feeling it’s because I deleted some Premiere Pro preview files, as before that, there was no problem…
  • Peter Mcauley
    May 6, 2006 at 6:10 pm
    Hello,
    If you are a registered user you have access to telephone and email support – I would like to suggest that you contact our support department who will assist you with this problem. You can reach them by sending an email to support@borisfx.com.
    I hope this helps.
    Peter.
