Activity Forums Apple Final Cut Pro Legacy Black compression in Compressor
  • Black compression in Compressor
    Posted by Rui Coutinho on November 4, 2009 at 12:40 pm
    Hi to you all,
    at the moment i’m exporting a music video for a band, this video will be released in their next album as multimedia track in the CD.
    So, I’ve done the edit in final cut, and make a basic color correction with the 3 way color corrector.
    I exported it as H264, after the encoding I realized that the encoding process had lifted up my blacks adding some noise…
    Does the black compression filter from the compression good enough??
    Thanks !!
    Jeff Handy replied 16 years, 10 months ago 2 Members · 1 Reply
  • Jeff Handy
    November 4, 2009 at 2:16 pm
    You could always try it. I have gotten good results myself. Use the preview feature in Compressor to test your black restore tweaks. Using preview will save you a lot of time with trial and error.
    HandyGeek
