Activity Forums Adobe Premiere Pro Black borders and scale issues
  • Black borders and scale issues
    Posted by Jesper Karlsson on June 7, 2009 at 9:10 pm
    Hello!
    I have edited a movie in Premiere Pro CS2, which I have exported to the h.264 quicktime format. The problem is that the exported file doesn’t look the same as it did on the preview screen in my project. The scale of the videos have changed, along with unexpected black borders on the sides. Since I have adjusted the scale in my videos to look exactly as they do in the preview screen, I would really appreciate if someone could tell me how to render a movie, so that the finished file looks just like the one on the preview screen.
    PS. I have allready tried to set the “Safe Area” option in the project settings to 0%, and “Scale to Frame Size” didn’t work either.
    Thanks in advance!
    Vince Becquiot replied 17 years, 3 months ago 2 Members · 3 Replies
  • Vince Becquiot
    June 7, 2009 at 10:56 pm
    Can you please post a list of your project and export settings and/or screenshots. No real way to figure it out without that information.
    Vince Becquiot
    Kaptis Studios
    San Francisco – Bay Area
  • Jesper Karlsson
    June 8, 2009 at 2:57 pm
    Hello!
    Here are my settings:
    Project Settings
    Frame Size: 720/480 16:9
    Pixel Aspect Ratio: D1/DV NTSC Widescreen 16:9 (1.2)
    Title Safe Area: 0%h 0%v
    Action Safe Area: 0%h 0%v
    Export Settings
    File Type: Quicktime
    Compressor: H.264
    Frame Size: 720/480 32:15
    Pixel Aspect Ratio: D1/DV PAL Widescreen 16:9 (1.422)
    Thanks in advance!
  • Vince Becquiot
    June 8, 2009 at 3:09 pm
    Jesper,
    You can’t really export from NTSC to PAL directly in Premiere because of framerate issues (if that’s what you meant to do), but if this file is meant for playback, I always export to square pixels.
    The resolution becomes 854×480 (1.0)
    Now, you may still see tiny black borders on the sides, but that’s because CS4 now exports with exact PAR. If that’s an issue, just use the cropping setting in the export window.
    Vince Becquiot
    Kaptis Studios
