Activity Forums Maxon Cinema 4D Black Border
  • Black Border
    Posted by Chris Walter on April 29, 2009 at 11:42 pm
    I have a material with a video on a plane. For some reason, there’s a black border around the video, any way i can adjust the size of the video? I know something about setting it to “flat” and then adjusting…but when i set it to anything but cube it’s warped and doesn’t size correctly. Anyone have a solution?
    Adam Trachtenberg replied 17 years, 4 months ago 3 Members · 4 Replies
  • Nolan Scott
    April 30, 2009 at 12:52 am
    Try UVM Mapping / uncheck Tile / select the Texture Tool ( you’ll see a yellow grid) /
    select the Scale Tool and drag in the viewport / select the Move Tool for positioning…
    Regards
    Nolan
  • Chris Walter
    April 30, 2009 at 1:39 am
    I apologize for my newbie ness, but what is the texture tool?
  • Nolan Scott
    April 30, 2009 at 2:09 am
    Left hand Tool-bar (mouse over the tools and watch the text at the bottom-left of the Cinema 4D window: = (Use Texture Tool)…
    Or go to the Top-Toolbar / Tools / Texture
    Cheers
    Nolan
  • Adam Trachtenberg
    April 30, 2009 at 4:46 am
    Ironically I was recently helping someone put a frame around a texture, but this video tut should give you what you need:
    https://www.3danvil.com/tutorials/tex_frame/texture_frame.html
