Activity › Forums › Adobe After Effects › Black border when using H.264 directly
  • Black border when using H.264 directly
    Posted by Olly Lawer on April 4, 2012 at 9:57 am
    I’ve just completed a HD animation and was looking for the best output settings from AE. I went with H.264 directly from the first output module screen, then tweeked the format options to CBR bitrate encoding and the level to 5.1 (these were the only settings I changed) and when I rendered and uploaded to youtube the results were stunning.
    Now I’m working on some anamorphic animations that have been sent through to me. I went through the same method as above, but stretched the image to 1024 x 576 (from 720 x 576). Now I see black boarders (top and bottom) on the QT that results and when I upload to YouTube.
    So I did a quick test (1 sec), selecting QT from the first level menu in the output module and then changed to H.264 and stretched to 1024 x 576 and the result was fine on YouTube. No black boarder.
    Weird thing is, when I try this for the whole comp the same problem results on YouTube. Now, this is where is gets weirder, the QT movie before I upload to YouTube is fine. No black border.
    Now, if I pre compose the layers at the top level and then change the comp size to 1920 x 1080, transform the comp to fit and continuously rasterise, then follow the steps I outlined in the first paragraph, the results are stunning. But I have been warned not to do this…
    Olly Lawer
    Multipasser replied 14 years, 5 months ago 2 Members · 1 Reply
  • Multipasser
    April 17, 2012 at 2:10 pm
    Yes. The normal workflow is Lossless -> compress in any lossy format.
    I also hate working with aspect ratio’s but the new ‘pixelratios’ in adobe CS5+ suites will give you black bars left/right, when you compress from a HD file to PAL widescreen. And there is NO way to remove it from Encoder.
    You will need to render out a PAL widescreen (720×576 with aspect ratio) out for it to compress fullscreen.
    This is propably due too the difference in pixelratios.
