Activity Forums Adobe Premiere Pro Black BG in PP2 Titler
  • Black BG in PP2 Titler
    Posted by Mbelli on April 28, 2006 at 4:40 am
    To get a black background in a title, I normally create a black rectangle object slightly bigger than the title’s safe margins. I then arrange the rectangle to the back and then place text in the front of the object.
    Is there a way to tell the titler to not superimpose the title by making the BG opaque instead of transparent?
    Mbelli replied 20 years, 4 months ago 3 Members · 3 Replies
  • Craig Howard
    April 28, 2006 at 9:30 am
    What you are doing should work but another way if you want a black BG – put the title you create over a Black Matte.
  • Tim Kolb
    April 29, 2006 at 3:19 am
    I typically just use a black video clip…it actually gives you a bit more flexibility as you can fade title before the video fades in…keeping the text and the talent’s face from occupying the screen over the top of each other, which I find annoying.
    TimK,
    Kolb Productions,
    Creative Cow Host,
    Author/Trainer
    http://www.focalpress.com
    http://www.classondemand.net
  • Mbelli
    April 30, 2006 at 1:20 am
    Wouldn’t it be simpler to just have an option to click “opaque” or simply select a color that you want the BG to be if you don’t want it transparent.
    The problem with a black matte underneath is one, if you have a lot of these kinds of titles you have to move and manage two clips now, secondly when you make a dissolve or a scene transition, you have to make it for both the matte and title.
    Going back to creating a black rectangle in the BG for a second. This also has a few problems. it’s easy to click the BG instead of your font and have to then to find your fonts buried beneath the rectangle. But with the rectangle I don’t need to create a black matte — but, when these titles come over someone’s picture, I then have to create a matte or it won’t fade out properly.
    An option to have a colored BG and not a transparent BG would really be handy, a lot of titlers have this option.
