Activity Forums Apple Final Cut Pro Legacy Black bckgrnd on Alpha 4444+ FCP export
  • Black bckgrnd on Alpha 4444+ FCP export
    Posted by Ignatius Gorin on November 16, 2012 at 4:34 pm
    Hi there —
    Desperately trying to export an FCP 7 comp where I need the initial and last frames to be transparent (to encode in FLV Alpha with Adobe Encoder).
    I tried pretty much everything I could think of, and all tricks I aw mentioned here and there, to no avail.
    Exporting from Quicktime compression, Alpha 4444 million, from v2 (tried v1 too), both rendered and unrendered, still getting a black background even when reimporting in FCP and checking against a white background (so I’m obviously getting the black background in Encoder too).
    I initially thought this was due to the fact that I use Perspective Reflection plugin on those tracks (never could export these with reflection on a transparent background, BTW). So I added a one second color clip before the video clip, with a fade in (transition) from nothing to color, then crossfade to clip with Perspective Reflection; still no luck). I only need the first and last frames to be transparent…
    Also, Alpha column is set to Plain in the browser for those files.
    Appreciate any help. TIA.
    Ignatius Gorin replied 13 years, 10 months ago 2 Members · 9 Replies
  • 9 Replies
  • Rafael Amador
    November 16, 2012 at 6:42 pm
    [Ignatius Gorin] “Exporting from Quicktime compression, Alpha 4444 million”
    You need Millions+.
    rafael
    http://www.nagavideo.com
  • Ignatius Gorin
    November 16, 2012 at 8:37 pm
    Yes, what I meant, sorry. Million+.
  • Rafael Amador
    November 17, 2012 at 9:01 am
    “Alpha column is set to Plain in the browser for those files.”
    Where are you getting “Plain Alpha”?
    FCP options aret:
    – None/Ignore
    – Strait
    – White
    – Black
    rafael
  • Ignatius Gorin
    November 17, 2012 at 9:27 am
    It’s set to simple (sorry I translated from the French).
    THanks for your help, as I’m stuck…
  • Ignatius Gorin
    November 17, 2012 at 10:28 am
    Erm… sorry, it’s set to STRAIGHT…
    Still stuck, pulling my hair on this…
  • Rafael Amador
    November 17, 2012 at 3:06 pm
    Hi Ignatius,
    I’ve heard often complains from people having problems to export movies with alpha even when apparently they have all the sequence parameters OK.
    Make a simple test:
    – Open a new sequence (whatever the settings), and change the codec for Prores444/Colors+.
    – Open the basic Text tool in the Viewer (you get “Sample Text on it) and drag it to the time-line (V1).
    – Export (QT current setting) and then re-import to FC. See how it works the Alpha channel when you lie it on top of any picture on any sequence.
    rafael
  • Ignatius Gorin
    November 17, 2012 at 4:05 pm
    THanks for your help Rafael —
    Here it DOES work. What can I try next ? Convert my own sequence to 4444+ before exporting? (Can’t try that right now, but I will later if you say that’s the way to go).
    THANKS.
  • Rafael Amador
    November 17, 2012 at 6:03 pm
    Yes.
    Set your sequence codec to Prores 444 Millions+.
    In the sequence setting, set also “Render all YUV material in High Precision”.
    rafael
  • Ignatius Gorin
    November 17, 2012 at 6:28 pm
    YES! That worked. Thanks a million, that really saved me.
