Activity Forums Adobe Encore DVD black bars on the side
  • black bars on the side
    Posted by Shaun Au on September 5, 2012 at 10:22 pm
    Guys,
    I know this question has been raised before. But I don’t see a clear answer to this question. I ran into the same problem when I’m trying to author a Blu-Ray in Encore CS4.
    I have a 16:9 clip(1920×1080 422HQ) which I want to use on my Blu-Ray as a motion menu. There’s no HD to SD issue here. Everything is in full HD. The project is set to 1920×1080 full HD Blu-ray. The interpret footage is also set to square pixels for the animation clip. So why I’m getting two thick black bars on the left and right?
    The screen shot shows the background animation added to the menu. There’re no buttons yet.
    This is an older post about the same question.
    https://forums.creativecow.net/thread/145/867488
    Shaun Au replied 14 years ago 2 Members · 4 Replies
  • Jon Geddes
    September 6, 2012 at 9:05 pm
    Can you confirm that your actual menu PSD is 1920×1080? You might have a 1920×1080 project, with a 1920×1080 motion background, but if your menu PSD is 720×480, there will be some downscaling and black bars.
    Jon Geddes
    http://www.precomposed.com
  • Shaun Au
    September 6, 2012 at 9:33 pm
    There’s no PSD menu yet. Just a new menu assset in En, then I added a motion background by selecting a .mov via the motion tab for the menu property. PSD is the next step, but I haven’t gotten to that point. All my stuff is in 1920×1080.
  • Jon Geddes
    September 6, 2012 at 9:42 pm
    You are in the “Menu” tab in the picture you posted, which means you created a “Menu”. A Menu is a PSD file. Try creating a new 1920×1080 PSD in Photoshop, then save it. Import that PSD as a menu into Encore, then import the background as an asset, then assign the motion background as the video/audio for the backgroun in the motion tab.
    Jon Geddes
  • Shaun Au
    September 6, 2012 at 10:22 pm
    The 1920×1080 PSD import as menu solved the problem. I was creating a menu within En and that’s what’s causing the problem. Thank you so much!
