Activity › Forums › Adobe Premiere Pro › Black Bars next to my video.
Posted by Kut Bayram on August 8, 2013 at 6:35 pmI keep getting these black bars on the left and right side of my videos when I am about to render them out. This is what it looks like.
Tim Kline replied 13 years, 1 month ago 3 Members · 2 Replies -
Ann Bens
August 11, 2013 at 11:08 pmI am guessing you are going from HD to DVD.
HD is real 16;9 SD widescreen is not.
To fix this go into the output tab in the export settings and set source scaling to Scale to Fill.———————————————–
Adobe Certified Expert Premiere Pro CS6
Adobe Community Professional -
Tim Kline
August 19, 2013 at 8:26 pmIt is probably your output settings. In the Render area, make sure your input Video Size and settings are the same as your output. If that doesnt work, you can also crop those black bars out in the render setting as well. Generally its because your Sequence setting doesnt match your video. You can also Size your video to match the Sequence setting in the Video editing time line. Just click on the Video and size it accordingly.
Hope this Helped.
Tim
https://www.fourtendigital.comThanks, and appreciate your response.
Tim K
Fourten Digital Media
Video Production
Carlsbad California
Website: https://www.fourtendigital.com
