Activity Forums Adobe Premiere Pro Black bar on the bottom of viewer “VIDEO PREVIEWS” PPCS6
  • Black bar on the bottom of viewer “VIDEO PREVIEWS” PPCS6
    Posted by Dustin m. Rosemark on March 22, 2014 at 7:02 pm
    Greetings,
    *Sorry if I use FCP terms, I am not a PP editor and have just moved to it.
    I am working in PPCS6 and I have a problem with video that shows up in the “VIEWER”. Before I render the video preview the footage looks normal and as it should, but after I render the video preview this strange black bar appears on EVERY clip. (see examples below). I did a test and found that this black bar does not follow through when I export the sequence to a .mov so that is GOOD.
    The problem is the footage I am working with is sometimes slightly smaller that the timelines size, which would produce a similar effect.
    I don’t want to find myself in a situation where I spend a long time exporting footage to a .mov only to find that there is a clip in there I missed because of this irregularity.
    Anyone know what is going on and how I can fix it?
    How the images look before rendering and after exporting
    How images look after rendering.
    Best,
    D.M. Rosemark
    Dustin m. Rosemark replied 12 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
