Black background?
This is probably an easy fix that I’m not aware of since I’m new to using Davinci … but … how do you remove the black that overwrites your video? The video footage still shows in the timeline, but after adding some images on various layers using cut and edit, now all my screen is showing is black?
This youtube clip (https://www.youtube.com/watch?v=fmKAjCQGdZo) demonstrates the issue, but the solution doesn’t seem to work? When I go into fusion everything is on one line …
… and though the picture shows it doesn’t have a background there, it somehow still has the black background?
Any suggestions?
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
