Activity Forums Adobe After Effects Black background removing!
  • Black background removing!
    Posted by Andrea Di berardino on April 19, 2013 at 9:49 pm
    Hi everyone, i am working on a project where i have to blend two footage.
    The footage that i have to blend is an hand (black and white) with black background. My problem is when i use luma key effects for remove black background, part of the hand is not visible because there is some black shadow on, and also is transparent. Which techniques is the best way for have clean subject (the hand) without black background? Thank you in advance.
    Andrea Di Berardino
    Dan Donaldson replied 13 years, 4 months ago 3 Members · 4 Replies
  • Fernando Mol
    April 20, 2013 at 8:08 pm
    Try the rotobrush
  • Andrea Di berardino
    April 20, 2013 at 8:20 pm
    Hi Fernando, thanks for your reply!!
    The trouble is that i try also with the rotobrush but does not give good result in my footage. Also do you know why when i use luma key effect there is little bit of trasparency in the footage? Thanks in advance
    Andrea Di Berardino
  • Fernando Mol
    April 22, 2013 at 1:28 pm
    Witout seeing an image of your project is hard to guess. Maybe you need to learn better to tweak those tools or maybe your footage calls for manual rotoscoping.
  • Dan Donaldson
    April 24, 2013 at 6:28 pm
    Hey Andrea,
    If the rotobrush is giving you problems, you could try manually rotoing the footage by using the Pen tool, depending on how long your footage is. Or, you can duplicate the footage and use the Pen tool around the area that gets accidentally keyed out. Again, this depends on the length of the footage.
    The Primatte keyer from Red Giant works wonders but it’s pretty expensive. Other than that, you could try using multiple Color Key effects or the Color Range effect. Maybe Keylight? It’s always hard keying out a background when that color is present elsewhere.
    Now, to your transparency question. When keying out a color, it removes said color from the entire footage. Your footage probably has some shades of black in the remaining footage that is keyed out along with the background. Since there is no longer color there, it leaves a hole which is the transparency you see.
    I hope all this helped. Good luck!
