Activity Forums Maxon Cinema 4D Black-and-white frames (problems with Standard and Physical Renderer)
  • Black-and-white frames (problems with Standard and Physical Renderer)
    Posted by Daniel Wayfarer on December 15, 2018 at 3:37 pm
    Hello everybody!
    I’m only begin study Cinema 4D and sorry for my English)
    I’ve created low polygon scene. While the scene is rendering, I notice the next problem: there is animated CameraMorph and some frames сome out black-and-white. If I don’t use any Cameras and render in the same angle, the frames сome out colorful. This situation is happening, when I use Standard and Physical Renderer (I don’t use another Renderer).
    I use HDRI light, big sphere with material (only with channel Fog, for sfumato effect) in the scene. If I delete the sphere (with Fog), black-and-white frames become black. If I also delete HDRI light (Standard Renderer options: Default Light – enable, Global Illumination – disable), all the same black-and-white frames become black. If added Physical Sky, black-and-white frames become black.
    I reset options to default (deleted option folder), created new renderer preset, created new cameras, but it didn’t help.
    If somebody knows, where I have the mistake, please write me what to do.
    Pictures
    Video
    https://yadi.sk/i/4ScEq9cDHhkDZA
    Justin Thomson replied 7 years, 9 months ago 2 Members · 1 Reply
  • Justin Thomson
    December 17, 2018 at 2:33 pm
    looks like it’s a multipass of the depth channel.
    When you get to the top, don’t forget to send the elevator down for the next guy
