Black and Code Wrong Timecode via Firewire to Panasonic 1200A
I’m having the following issue trying to black and code, and then edit to tape via firewire to a Panasonic 1200A, recording at 720p59.94. I am using a Mac Pro and when I try to black and code, the wrong timecode is put on the tape. For instance, if I choose to start at 00:58:00:00 (the default), the TC will start at a random number, like 01:30:22:10. I have deck control, and black is output, but the TC is wrong. What is puzzling is that correct TC is output via print to video. My system has FCP 7.0.3 and Snow Leopard 10.6.6, on a Mac Pro Octo-core Intel Xeon, with 8GB RAM.
I have tried everything I can think of to isolate the problem, including the following:
1. Repaired permissions
2. Zapped PRAM
3. Reset SMC
4. Logged in as different user. Same problem.
5. Tried to output from a different computer. I did this from my MacBook Pro and it worked perfectly. So it’s not the deck settings, it’s not the firewire cable, and it’s not the tape stock.
6. Removed all 3rd part PCIe cards: Blackmagic Decklink Studio 2, Sonnet eSATA card, and OWC firewire 800 card.
7. Deleted Blackmagic software installation
8. Installed new system on a new internal hard drive, and then installed FCS 2. Same problem outputting correct timecode.
9. Ran Techtool. No problems reported.
10. Tried both front and back firewire ports.Outputting to this deck has worked for me in the past, so I’m not sure what would be causing FCP to output the wrong timecode. The Mac Pro is past the 3-year AppleCare term, so I’m hoping the hardware is not the problem.
Any ideas?
James
