Activity Forums Apple Final Cut Pro Legacy Bizzarre (sound related?) Scrubbing problem with DV files.
  • Bizzarre (sound related?) Scrubbing problem with DV files.
    Posted by Josh Evans on June 15, 2008 at 7:37 am
    Im using MPEGStreamclip to convert some DVD files into DV files.
    I import them into my timeline, and at first they scrub fine, very smoothly, with sound scrubbing on.
    Then for some strange reason, after I leave them for a while and come back, they only scrub well with sound scrubbing off. For some reason, with the sound scrubbing on it scrubs terribly. Is this some sort of sound setting related issue? It just seems weird that they work, then dont, with absolutely no changes made.
    Josh Evans replied 18 years, 2 months ago 2 Members · 2 Replies
  • Ben Holmes
    June 15, 2008 at 11:24 pm
    Is the audio and video on the same drive. Almost sounds like an external drive went to sleep, as it was occuring after you left it for a while.
    Ben
    Edit Out Ltd
    FCP Editor/Trainer/System Consultant
    EVS/VT Supervisor for live broadcast
    RED camera transfer/post
    Independent Director/Producer
  • Josh Evans
    June 16, 2008 at 4:25 am
    No my scratch is set to one external drive. But that did sound like a good guess, since it seems to be the audio only that is causing some sort of lag.
